Does it sound boomy at all?
I should be picking up one this week, you sound like me who wants a nice quiet exhaust, so i'll let you know what its like.
you wont have to tell them! you can hear it from about 5 miles away!!!
wait and see fella! have you got a cat? i heard it with a decat! it sounding like jason plato at full throttle!
ktec system is very nicely made, lots of adjustment. with a std cat it sounds fine....
You can but you don't need too!! Drop the rear beam, x2 17mm, piece of piss, takes 10m max!
markcup, did you have problems with you decat/manifold flange hitting the heat shield of the steering column
i have that problem at the moment.
(also pm'd you on renault sport, awaiting reply)
All you need to do is undo the 17mm bolt that holds the shock on each side...... of the rear beam (x2) thats it!!! Then just jack the car up to desired height![]()
Just to check - this is wrong isn't it!!!!
