Christopher
Z4M
Did anyone ever overcome the gearbox issues with fitting the Megane turbo 2.0 into the Clio? IIRC Fred had a little project on the go but he needed to cut the leg or something to make clearance for the gearbox?
That sounds like a project that would be worth it's weight in gold if it could be made to fit.
Knowsit. A relatively cheap 260bhp Clio conversion. IIRC there some quite serious problems though, and the 182 5-speed gearbox doesn't fit the engine either (again, IIRC)![]()
Engine fits. 6-speed box... does not. At all.
You can't use the 1*2's JC5 'box on it either, since the bolt-spacings are different, amongst other things. You could, if you had the money, get a housing CNC'd with new correct fittings, but surely that's missing the point, as it's no longer a cheap "plug and play" conversion.
Pity, really.
