If the K-Tec coilovers are the same as the Raceland ones (not looking to get that started again), then they will use bolts similar to the one in the below link.
The strut may still have a round hole, but will have a 'U' shaped slot for the bolt to go in. I took this 'U' shaped slot off my raceland struts so I could use the Eibach bolts.
*EDIT*
Just noticed you mentioned the coilovers haing the cup bolt spacing. I have no idea how the bolt spacing has been modified, so can't comment on that part.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
