Before you all rush into saying silly things, some valuable information might be that i'm recovering from a broken elbow, 2 fractured wrists, a torn thigh muscle and a dislocated thumb.
So yes, work has taken a massive hit.
Sadly not, he asked me to comment if anybody asked a question.
And the cropper is otherwise known as DH mtb'ing...............you should try it.
Where are you expecting peak power, rpm, with such a short inlet?
Rpm range is limited on the stock bottom end, so the entire engine is geared towards torque production. Cam is not that wild, valvetrain is stock, but we have incorporated ultra high velocity porting to shift the curve left and offset the short inlet. Simply aiming for peak power to be 6.8k with as much area under the curve as possible.
Could the same theory be used on the F4R?
That is, short inlet with headwork to get the same peak power point as long inlet with no headwork.
The world would be a boring place if we all drove Clios with white wheels![]()
Too many WIP threads on here, I'm jealous....
A few of you know my car has been at Angelworks for a while now but it's nearing completion so I thought I'd share sopme sneaky shots of the plenum set-up that's going on. This is a complete one-off and has been designed and made by Ben and his contacts.
K4M....
Inlet and injector set-up
Another veiw
Now, this is how it would have look had we had enough room ro use the Formula Renault plenum but the thermo housing is in the way so Ben's making an alloy one to get around it.
Spec when finished-
Custon inlet/plenum set-up
AWT headwork
Cat Cams
A/C removed
Prospeed cat-back with Superspring de-cat
Depending on how that runs I'll go aftermarket management with a bottom end build to run higher the RPM i need to make more power.
I could have gone 172 conversion but where's the fun in that?
I'll keep this updated as and when the car is back and I can fit the mountains of stuff I've got in my room!
Thanks for the comments so far folks. It's good that everyone understands the reasons behind it, lol.
Management is bothering me though....Do I take the plunge??
VEMS. Mainly due to price and wideband control.....
Can I steal this when its finished?
The quality of the machining and look of the brackets is spot on.
Attention to detail on all the parts I have seen so far is amazing!
Its a stark contrast between companies that can produce bespoke machined engine parts and companies who just bolt bits on. It certainly seperates the engine tuners from the garage mechanics.
I dont think Ben has released any pictures of his ITBs for the F4R yet but from what I have seen they are of a similar machined from billet quality piece of work.
The proof is in the power though so if gains can be achieved then I dont see any reason why people would want to bolt a set of Jenveys on to there clios ever again.
Now Ben has taken the steps towards making his business work I am sure there will be alot more exciting trick engine bits to look foward to.
Can I steal this when its finished? lol. Have to see this in the metal when its done! I love the idea of high output 1600's
Absolutely! The quality of work is amazing and the fact it's all designed and machined to custom specifiacations makes it even more impressive. I've ssen the DTH bodies he has and they make Jenvey look s**t to be frank! Hopefully see them bolted to your car soon
For all the doubters though, this proves without doubt what Angelworks can do. Bolting something to a car takes a matter of hours, physically making and researching the part is a whole different ball game....
