hi, I have a 2001 megane 4 door 1.6 16v k4m
. I have started a k4m turbo project this year february and have been using the set up until now.
the internal was stock
2 original gaskets + 1 1mm steel gasket the compression ratio: 8.5
IHI (t2 size) turbo
8lt intercooler
60mmcustom intercooler and turbo pipes
60mm exhaust
sierra cosworth 440cc injectors
aem fuel regulator
greedy e manage blue box
the first dyno output was @.7 bar 176 hp and 198 nm without the greedy map
after the map and @.9 bar with front end 60mm back end 51mm exhaust 201 hp 275 nm
after 60mm exhaust completely, @.9 bar 215 hp 309nm
last week my stock rods were bent, this week I have found new stronger rods, changed the piston rings etc made a new engine. I will post the pictures and videos soon. you can serach from youtube "ankara megane turbo" I have some videos with 175hp against a clio rs mk1 with intake exhaust and 15/61 differential
so far I have passed 250 hp wrx sti, cai s2000, cai headers 60mm exhaust type r.
after the engine is finshed new videos will come![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
IHI (t2 size) turbo
8lt intercooler
60mm exhaust
aem fuel regulator
