knocking when wheelspin???
  Leon Cupra 300
Had this a couple of times i originally thought it was the engine mount, but if say your cruising in 2nd and the accelerate hard it doesnt knock or anything so im assuming the engine mounts are ok.
It only happens when the wheels are spinning, i had it yesterday when had to dive onto a roundabout fairly quickly in the wet, the wheels spun but it was like they are bouncing a bit but it sends shudders though the car. it never does it in 2nd when they are struggling for grip though!
and also did it in the dry when did a standing start, the wheels were just slightly spinning, then this fcuk off knocking would start along with the bouncing.
at the moment im hoping that a change in tyres might help it, and dont say use less throttle everywhere because that doesnt solve the problem and its something my old escort or corsa never did.
strange :S
  Pink & Blue 182, JDM DC2
  tiTTy & SV650
there's a name for it but i cant remember it...
happens on any FWD when you spin up the wheels, i did it in a 60brake fiesta.
If its particularly bad it might be a mount issue.
  Leon Cupra 300
i dread to think what it sounds like on the outside, its horrible in the car. will see what happens when change tyres, im on contisports at the moment but pe2's are going on next!
  Leon Cupra 300
rory182 said:
lol axle tramp? the name I was looking for
whats the definition of axle tramp?
want to know what is exactly happening when i hear it, what is actually making the noise. should i just not worry about it or try drive around it:)
sounds like drive shafts are on there way out to me, shouldn't do that. only time my car did that was when the shafts were about broken...
Clart
all mk2's do it, sounds terrible in the rain. suspension mounts or something isn't it?
C
clio172cup20
It does sound like the drive shaft, not very strong in the cups.
.. on the other hand... does the cup 172 has a LSD (Limited slip dif) gearbox?!? is so it sould be that.
lol, no mate, cups just use the same box as the rest... it's the same car you know!
I'd be worried that they all do it, as it's something you should only hear if your drive shafts are on their way out... having said that I wouldn't be surprised if they came new with some kind of manufacture fault causing this, would be typical of Reno.
as Vicky also says, dont wheel spin it, use a bit of throttle control, it's not like Clio's are hard to launch fast without spinning anyway, grip's never been a problem!
  tiTTy & SV650
no LSD...
It's just lack of traction and wheel spinning sending forces through the suspension causing the wheel to bounce up and down and make a nasty noise not done it for over a year but my mate did it in his 1.4 306 the other day oh how i cringed.
  Black 172
No car is really made to wheel spin in anyway but it looks like its caused a probelm or you have found a problem whist doing it.
  Leon Cupra 300
I think your theory souinds right rory about the wheel bouncing. It must get to a certain resonant frequency that causes the repeated bouncing, because if its spinning and im at full throttle it makes no noise its only if im on like half throttle (trying to be careful!!!)
  Leon Cupra 300
fair point but if reno are going to make a 170hp fwd car with no traction control they should kinda expect it to wheel spin at some point, specially in the wet!
think ill just deal with it, suprised there isnt a fix for this though
  Black 172
Ahh you see i have a full fat 172 i have never driven a cup properly, mine does wheel spin but hey i am a girl i dont race ;)
Martin_172
mine does it in first and even in 2nd if your pissing about in the wet at roundabouts or junctions. fuks engine mounts tho mine jumps out of gear sometimes coz of it lol
  BLACK 197!!
does it knock when your steering is on full lock???????
my mate is renault mechanic and apparently there is a common fault with strut tops fouling and its supposed to be easy to fix but its common on all 172's
  ph1 172
I think i know what this is...
Its the top mounts coming to the end of their travel and the nut knocking on the shell.
Have a look round the top mounts and see if the paint has been chipped off by the big top mount nut round the edges of the 'hole'.
As the wheels gain and then lose traction over and over, the shock is pulled back so hard that.... well it knocks the top mount. French design at its best!
Tim
Gaz_
  Extreme mode
easy fix this!!!! its the engine hitting the subframe/ and or steering rack, not axel tramp etc
i sorted mine by getting the uprated k tec dog bone mount.... and then slacken off the 4 bolts on the left hand engine mount (the one near the oil cap lol) pull the engine forward with the help of a bar/mate then re tigthen the bolts. Job done, mine never does this now, no mater how much right foot is given in 1st
  172
I think I'll just not put too much power down.:S
Gaz_
  Extreme mode
easy sorted though, dont put up and shut up, get it fixed lol!!!!
  172
I still haven't gotten round to removing the Elf sticker yet three weeks after posting about how to remove it, like I could be arsed to do all that lol.
  182 Cup
By the way according to Evo, the new 911 turbo suffers from axel tramp under hard acceleration too. So don't just put it down to the car being cheap.
  182 Cup
Got an answer on this from the experts:
Inferno asked 182 wheel hop?
Under hard acceleration that culmanates in the front wheels loosing traction in wet conditions (electronic aids on or off) it has been noticed by a number of owners that there is significant driven wheel vibration - possibly wheel hop. This is not a problem that I have experienced on any other modern fwd car, is the suspension design on these cars significantly different to other fwd cars and is there anything that could or has been done to reduce the effect?
Allen Collen responds:
The suspension design is classical FWD. The simplest solution is to ease the power on in accordance with the conditions, the ESP strategy will allow a degree of slip, but when it breaks traction completely the reaction vs. the physical is very difficult to control. Sure the further up the technological scale we proceed we can find a solution, but for this car / application / market the systems that are supplied are the most durable / suitable and cost effective.
Looking at 'wheel hop' more on the net... not liking what I'm reading...
"The number one reason people end up getting a Quaife differential in a FWD Eclipse. Wheel hop kills the stock diff. Once a piece of the stock little spider gears breaks off, the spinning diff housing droop kicks right through the bell housing and into the clutch. Ouch.
If you are making good power in a FWD Eclipse, you can get a Quaife before or after you make this mess."
"Wheel Hop
The other major culprit is wheel hop. Folks, do NOT ever allow wheel hop to occur. If you feel it beginning, lift off the throttle...NOW. Wheel hop is a smaller version of the phenomenon described above, but in a way, it's even worse...with every 'hop', the over-torque occurs. If there's ten 'hops' before it stops hopping, which can take but a couple seconds, that's ten death-blows to the driveline.
Slicks tend to eliminate wheel hop due to the 'resonance' of the floppier slick tire as compared to a stiff street tire. Taken another way, the slick acts as a shock absorber, stopping the wind-up and release of suspension that causes wheel-hop."
This appears to be a subject that is talked about by many fast fwd car owners, particularly ones using their cars on the quarter mile, the main points I can see from other threads is that there are 3 main areas that need looking at when trying to reduce wheel hop:
1. Tyre choice
2. Suspension set up (many say stiffer to reduce wheel hop)
3. differential choice (Quaife ATB appears popular)
Traction bars were used to great effect on my Capri and wheel hop was eliminated, now I realise that the driven wheels on this car had a completely different suspension set up of leaf springs and a live rear axel, but is there no scope in fwd suspension set ups to use traction bars of some kind?
on the clios the TC system closes the throttle by varing degrees to limit power.
its able to do this as its Drive by wire,
the knocking is axle stamp (or whatever its called - I can never remember)
oddly enough the more power you have the less this happens as the wheels just break traction without jumping...
Andy
GDI
  172
"Wheel Hop
1. Tyre choice
Andy
GDI
Cheers. I wish he'd been a bit more consise in his answer tho!
muz
  big fat japanese bus
hmmm sounds a good cure this!
