clio 172
I'm going to fit these on the weekend.
Which parts of the original shocks do i need to re-use ? ive took all of the top mount pieces off but not sure if i need to use all parts of them or just the rubber part ant the top part ?
also is it worth getting solid top mounts ? Which one to get, seen the k-tec ones and the ast ones
also tighning the nuts on the lower ball joint, how do you stop the bolt spinning when tighning the nut ?
any advice would be great
