Lambda and Top Mount??
Drew.
alreet,
i'm so nearly there with this ph 1 172, just a couple of things left to fix.
i've read you can swap the lambda's over, post and pre cat, i fancy doing this to see if it helps mpg and cold running, mpg isn't that pants but i never really see anything above 31, i've done plugs and leads, my question is will the shorter lambda reach if i swap them round??
the one other prob is infamous suspension knock...is this all i need to rectify the knocker
http://www.eurocarparts.com/ecp/c/R...127e72120a4e70697498b8ec8ece191b2383733a&FLXM
or do i need the top aswell??
http://www.eurocarparts.com/ecp/c/R...628cd127b0681419f74463c1c52924c02f2ee8ce&FLXM
ta for any wisdom
