Laptop back up discs or help?
Car  Audi A3
Ive got a 2 year old HP pavillion dv-6 laptop, which is broke.
i know it was never the best around but it comfotably did what i needed it to do. now however when i switch it on on, its got a normal mode and a recovery mode, go through recovery and a blue screen appears.
Ive also tried all the F8 F10 and F11 key options and nothing seems to work.
any thoughts what i could do, and if its a recovery disc option, where do i get them from?
cheers guys
My DV6000 came with Vista :dead:
I'd recommend sticking Win 7 on it ANY day! Makes it much faster and easier to use!
Only thing that doesn't work on mine now is my remote control :(
What do you want the backup discs for? Do you no longer have the recovery partition?
All HPs come with recovery partitions. It's a split in the hard drive that the recovery "disc" is on. It's not a disc as such, but the same as. You can boot into the recovery partition and it's the same yet faster as you eliminate the need to read from a DVD.
If that makes sense :S
I don't have one anymore so can't say specifically. I upgraded my HDD.
On boot it should say "Recovery" or "Recovery Mode"?
Sorry I can't be more specific
Just go into my computer/windows explorer, you should have c:\ drive and d:\ drive called recovery.
Cheers for the replies fellas.
Just got "start normally" or "start recovery"
When I choose the recovery option it just loads up a blank blue screen and stays like that. Think I I'll have to buy the discs unfortunately
How long have you left the recovery mode to start up for? Sometimes it's painfully slow. I've waited 30+ minutes before to boot into it iirc :/
