if your engine is the same as mine (K4M) then the upper gearbox/engine mount will cost you just over £90 then you will have to get the lower mount from renault as the 1 on ktecs site does not fit (172 only)
ok upp gearbox engine mount i got made up from an engineer next to my mates garage when i got clutch done.. so lower mount ill jujst get from reno then
Get your mate to order it in if he will, save a couple quid. Also i advise you to fill around the rubber mould with sealant, just to give it a bit more stability as it seemed a bit to flexible to me.
