i got some apex 40mm drop springs cheap was going to put them on, but car handles really well on standard setup just dont like the high look. anyone else put these on? dont wanna put them on then find ive fucked the handling.
They aren't great no but at the same time they're not the worst out there. Eibach is what you should pick up if you're just looking for springs and want a decent quality set.
i've got apex and to be honest the ride is a bit gash. hit a pothole with these and you know about it and they fling you about a lot! Ride heights good tho, no way would i go back to standard tractor height. coilies next.
Make sure they aren't Gaz or other budget abortions if you're going the route of coilovers. If you fit them you'll have fond memories of the comparably smooth ride you had with the apex.
really!? i didnt think the ride could get much worse! I had a 205 1.9gti on std shocks with -60mm spax and that was a joke. gaz are budgets?? thought they were like 600 quid
I had both in the past and Gaz were worse than the Apex for ride quality and handling. IIRC I paid about £500 which IMO is towards the cheaper end of the market.
they are crap. if you know little about ride and cornering you'll disagree but i tell you now... only because they are on my clio, they are shite. dont bother.
just got a clio sport 53 plate few weeks ago it had the lowering springs on it when i got it. had to put a new drivers side driveshaft on it because of the angle the driveshaft sits once the lowering springs are on it ........so i took them off and put standared ones back on it
Coilovers can give a better ride quality than standard suspension it's just that most (seeing as people on here tend to buy cheap s**t in an attempt to get as low as possible for as little as possible) budget sets will make it worse. Invest in decent coilovers and the ride will be fine.
