Major Laptop Error!! Help!
Evening, My partners laptop takes about 10 minutes to load up (Normally takes 1) when it does its painfully slow, in a way that it's far to slow to do anything. Managed to run disk check - No errors + Virus scan - No Viruses.
Any ideas?
Sy
What operating system is it running?
Im running vista on mine, and when i noticed it was slowing down, it turned out while i was fidling with the power settings, i changed the max cpu performace to 25%.
Have you done a spyware/adware scan as well?
defragment using perfectdisk or similar, and make sure pagefile is a reasonable size. Remove any unnecessary apps (particularly those that run on startup) and use Sysinternals Autoruns to check what runs at startup.
