Making the Rear a bit more lively
.Joe
Good Morning,
when I was last out on the track the rear end didn't feel lively enough, I felt as if it was making the car a bit slow out of the corners.
my setup is below
Spax RSX F- 10 clicks from hard R- Hardest setting
Yoko AD08r
Whitelin on hard
Any idea as to what it could be?
Many thanks,
Joe
If you make the front softer and increase the stiffness of the rear, also increase the rear ride height these cars work best with the nose down .
  172
I've never experienced oversteer in my Clio once! The back end goes light over 100mph but thats it!
Thats on a standard sport 172 (understeer machine)
.Joe
Give it some toe out on the rear. It'll be lively then.
What's the geo on the car currently?
It's been set up by mark fish, has about 3 degrees of front camber.
Will i need shims for the rear? I'll be taking it for a hunter alignment in the near future.
At the moment it feels quite subdued not letting me push it any more.
NorthloopCup
Yeah you'll need shims to adjust the rear toe. You need to get the alignment measured first though.
  Clio 2.0 RS 172 Ph1
If you have the coilove type rear damper, you could always look at a stiffer rear spring.
I have the same suspension set-up as you (OP) and I tend to find its Very neutral. I find the rear grips well and that its more likely to pop up on three wheels than slide, bags of LOO in the wet though!
.Joe
I'll be taking it for a hunter alignment to get a print out over the next few weeks.
would Pure Motorsport be able to make shims up for it?
I find it quite dull so to speak and feels like it needs to be a tad stiffer.
when I last spoke to Mark he advised that I should get some of the Gaz rear coilover damper and bring the spring rate up.
NorthloopCup
Yeah they sell shims mate.
