Marks on bonnet because of shutting...
Ali
Car  V6, Trackhawk, GTS
Random...But the previous owner of the Vee clearly was a prat as there's a mark from how he's closed the bonnet!!
Now dent removal on panels is fairly easy as you can get access...But on the bonnet can they be removed...Granted they are small, but i want it perfect
Any one had a similar experience. Getting a lad out to see it this wk.
I have some on mine from the Factory/Dealer. My mate is going to do them using the hot glue technique of PDR - reckons they will come out.
whats the correct way to shut it then slam it for a small height 40cm or w/e
or close it then push it properly shut?
They say to drop it from a sensible height, so I guess about 30-40 cm. The Renault bonnet and suspension is all a bit rubbish though in my opinion, I hope the newer generation are better? Never opened the lid on any new RSs yet...
Rite....cheers rich i'll spk to the chap when he comes by, although i'm 100% sure mines worse than yours.
I dented mine had a carbon one for ages that you had to push down then when i put the original back on forgot and dented it! oops! Costs £40 to get fixed.
PDR is the shiz - pretty sure that will get you sorted, although never noticed any dents on your car in photos so can't be too bad!
