As above, impressive for a 1.2!
Did you by any chance see the Clio tce ktec mapped a couple of weeks ago? Insane! Have a look on their Facebook
ahh right so the actuator is controlled by the ECU map, not a physical setting on the actuator its self?
also could this be why the engine is developing a missfire?
Basically it looks OK except for the following;
- low grade fuel
- Boost actuator seems to have to much preset
- Spark plugs worn ?
Please check plugs and wastegate preset pressure / sticking if the
problems persist on RON97/98 Fuel.
however this has proved not the case and its ok saying its maby worth just getting it mapped properly but ive just spent £300 on the RS tuner which is useless!
Henk has me a new map with more coil energy which as far as i can see will highlight if the ignition system is at fault, so lets hope it points us in the right direction and i can enjoy my purchase!
You know my feelings with the customer service Martin. Leeds aint all that far away!
im not sure i understand this? the has been ran on Vpower and tesco99 and both have the same issue, i have no other option but to purchase race fuel to get higher quality fuel?That is not a problem at all, just stop bad mouthing my work. If there is an issue I always sort it out. But it can take some datalogging exchange of information back and forth.
And if its running on Tesco 99 I dont see knock correction which is the case on your car.
John had issues a while back with an RS Tuner not working with an unlock code.We are both in business for a very long time. I even longer than Paul. So my customer service cant be that bad as i suggested here ?
Unless I'm missing the point dramatically, what is the point in downgrading your car to save money, to then spend loads of money doing stuff to the new car?
I felt i had hit a brick wall after explaining i was running new sparkplugs, leads and best quality fuel, to then again be told it must be the plugs, leads or fuel.
