Megane brake pads - opinions?
Danith
  GTi 7.5 pp/Mx5 nd2
Yes, ANOTHER question on pads.
My requirements aren't so straight cut though. It's an everyday car, commuter, weekend blaster, etc. BUT I'd really like to take it on a track day or two this year and don't want to have to compromise so much or end up in a tyre wall.
So, R26 - currently on HC discs, M1144 pads, braided lines and as far as I know, OEM fluid. I've been buying the parts in bits as it's been an expensive few months! So I have 2 litres of ATE Typ 200, some new Brembo HC plain discs and a caliper seal refurb kit (and spare calipers just in case of any issues)
Pads then - been asking a lot of questions on the FB groups and still haven't decided on a particular set. Here's what I think so far:
Mintex M1144 - cheap, decent cold bite, low dust, don't handle heat very well, won't be up to it on track
DS2500 - common choice on a lot of other cars, but seem to fade quite easiliy on the megs
DS3000 - same price as DS2500 but will kill my discs and no good for an everyday car - poor cold bite
DS 1.11 - sounds like a winner but don't fancy spending £200 on a car that's 90% every day sat on the commute
CL RC5+ - sounds a good choice for me at the moment, decent if managed on track - just not sure if they'll squeal too much everyday on the road
Performance Friction Z rated - low dust, good cold bite, £100, last long, just may fade a bit on track
Cartbotech XP8 - not really looked into them, sound expensive and overkill
My main priorities are - good cold bite but able to be relatively reliable on track. Low(ish) dust and minimal squeal
I know I'm asking too much to be best for both worlds - I'm swaying towards PF Z at the mo or CL5+
In terms of track day hero status, I'm a relative newbie. Only done 4 (in my civic) but I'm an annual visitor to the ring (cliche of all petrolhead cliches)
Another option is to swap pads out - but then there's the suggestion that you'd need to swap pads AND discs (road pads bedded into one set of discs and track pads for another?). Which is not something I can be bothered with for just a couple of track days.
  dan's cast offs.
fitted loads of 1144 and apart from my own ones not found them to be a noisy pad. only fitted few sets of 1155 and they don't seem to be that bad in the scheme of things, not enough to be embarrassed driving around town.
Danith
  GTi 7.5 pp/Mx5 nd2
Got the M1144 in now. They are squeaking but think it's more because of a small lip developing on the disc.
Danith
  GTi 7.5 pp/Mx5 nd2
I used ds2500 daily, and at Spa. Never had any fade issues.
Yeah, had them on my civic, they were alright. People's reviews on the meganes though is that they're good but not great as easy to get them to fade
OE for road and some proper track pads for hooning off road. No need to worry about changing discs as long as both sets of pads have been bedded in properly and the discs have too. I swapped and changed all last year from road to track pads all coupled to the same HC discs, zero issues.
No point burning through track pads for road use as its money wasted unless you drive like a total bellend on the road, and I know you don't. You can always sell on the Track pads as well if they're not being used...
Danith
  GTi 7.5 pp/Mx5 nd2
OE for road and some proper track pads hooning off road. No need to worry about changing discs as long as both sets of pads have been bedded in properly and the discs have too. I swapped and changed all last year from road to track pads all coupled to the same HC discs, zero issues.
Yeah but cba buying another set of discs as well.
Been looking at options all weekend now and looks like I'm going to get the pf z rated and motul rbf600
ForceIndia
  Gentlemans spec 200
If you clownshoe it and stamp on the brakes line you're qualifying for the Belgian gp, they're right. Normal track use with a bit of mechanical sympathy, they're good. But the 2 pad solution above is undoubtedly better.
Danith
  GTi 7.5 pp/Mx5 nd2
I don't do enough track days in the meg to justify it. Just fancy taking it out on one and seeing how it fares in comparison to my honda and don't want to die
Danith
  GTi 7.5 pp/Mx5 nd2
Thats not so bad then. Think I'll go pf z rated as they were decent on my E36 328, good cold bite and sod all dust. If i need something more hardcore for track ill chop em out
Knuckles
ClioSport Admin
Are the meganes much heavier than mk3 Clios? I've not had ds2500s fade on me yet with hc discs and ate supergold.
I'm in a similar situation to you in that the car is a daily driver and occasional track car.
Although you may be more experienced than me or harder on brakes than me on track.
Danith
  GTi 7.5 pp/Mx5 nd2
Ha not guilty mate. Im a track noob. I'm just old. Apparently so yeah the megs arent racing the Ds2500
The oem brakes have a good bite but they do feel spongey later on.
Knuckles
ClioSport Admin
I had an awful experience on oem pads at oulton, I was getting such bad judder I could barely get the car into gear.
Fitted the ds2500s and was stomping on them all day at Blyton, Anglesey and oulton(before the breakdown).
I wonder what's so different between the clios and megs, same brakes, similar hubs and similar sized cars.
Danith
  GTi 7.5 pp/Mx5 nd2
They'd probably be ok to be honest. Just going off what other megane owners have said - I remember them being a lot more screechy than my PF Z as well tho. Really hate brake squeal when driving round town!
Knuckles
ClioSport Admin
Oh I'm not arguing sorry, if Meg owners have experience of them not working then fair enough. But I can't get my head around how they're fine on mine but not megs... And 182s it seems.
People hate them on mk2s too lol.
/shitdriver
Danith
  GTi 7.5 pp/Mx5 nd2
People cream all over them on the EP3 pages - well they used to, seems like track pads are much more common place these days
Knuckles
ClioSport Admin
I'm aware they're not the best on the market, but they bang on for what I need at the moment. They're Not squeaky, don't fade and bite from cold... And seem to last a while too
  Clio 182
I had oe pads on a meg 225. They were awful.
I fitted rc5+ and they were a huge improvement but the dust ruined my wheels.
I'd find a alternative personally.
Danith
  GTi 7.5 pp/Mx5 nd2
Thats convinced me then. It was between the pf z and cl5+
  Clio 182
The dust built up a thick crust layer and I had a coating underneath to prevent it.
Had to use acid on them to clean it off and took half a day.
I'm sure if you clean the car weekly it won't be a problem. I'm not that guy.
  Mk1 Focus RS
Ds1.11 like you said, sounds like a winner, I love them, yes they are expensive but I can't falt them and should you really buy cheaper brakes just because they are cheaper
Also where did you buy your seal kit from? Thanks
Danith
  GTi 7.5 pp/Mx5 nd2
Just off ebay mate, I think ECP sell them too. I got the kit for £28 with the bleed nipples as some kits just sell the seals.
Danith
  GTi 7.5 pp/Mx5 nd2
DS1.11 are raved about on the meg pages but for a car that spends most of the time sat on the M60 commute its way too overkill.
  Trophy,R26,GSXR1000
I tried quite a few sets on both mine and my little bro's R26s. OE, HC and AP 2 piece discs. PF, DS2500, DS3000, DS 1.11 and DS Uno. The best combo were HC discs with DS3000 pads, admittedly I could destroy a set of pads on a trackday if pushing on, but for feel and consistency they were the best combo by far. Uno's lasted longer.
Danith
  GTi 7.5 pp/Mx5 nd2
90% road use tho the ds3000 will leave chunks on the disc and arent great cold though
  Trophy,R26,GSXR1000
I didn't find any contamination on the discs with the ds3000s. But the DS2500s were awful for it on the AP 2 piece.
charltjr
Sorry to resurrect this one, but I'm pad shopping for the 200 and considering the DS 1.11, but they're listed as not for road use. Is that just a regulatory thing?
Currenly running DS2500's and while I've had no issues with fade I'd like something that doesn't give so much disc transfer for my next set of pads. Low dust would be good too, not so bothered about squeal as it's not a daily, so the 1.11 seem to fit the bill.
Ol’ Tarby
  Clio 220 Trophy
I've just fitted DS1.11 to mine. Give me a week and I'll let you know how they are. Got Anglesey next Sunday
Danith
  GTi 7.5 pp/Mx5 nd2
All the reviews I've heard for Ds1.11 are very good. Dont think there will be a problem. Bit overkill for me at £200 tho
Sash
  A Yellow One
I've got Brembo HC discs and DS2500's with SuperGold fluid on my Megane which has seen 30k of use last year which included 7 track days, fast road and motorway.
I haven't experienced any fade yet and still got plenty of meat left on the pads. They squeak a bit but that's just because where they've got hot the lubrication has melted away.
