megane brake setup
  Mk3 clio 1.5
Okay so I maybe breaking up a megane coupe 1.6 16v and i noticied the brake sie is considerably bigger. mine currently been 238mm and that been 280mm. the caliper piston is the exact same size, but would the mountin bolts line up with the holes?
Im not sure what you mean could you just rewrite it?
I think your saying the coupe has 238mm disk and your 172 has 280mm disk?
  Clio MK2 1.4 16v
I believe not.
Megane's have different mounting caliper holes than yours as far as I know. Your best bet is the 259 from a 1.4-1.6 16v or clio williams
  Clio MK2 1.4 16v
He means the other way round. He has a 1.2 brakediscs and wants the 280 from the coupe
Arr right he says he has a 172 in the car details though hence wondered how he would have small disks although it has happened before.
  Mk3 clio 1.5
I believe not.
yeah caliper seems quite a bit larger, but unsure on the mountain points. okay thanks for your help.
1.2 172 ;) 1.2 with the 172 kit haha.
