As quite a few of you know, I got rid of my MK2 quite a while ago now, and havent been around much on the forum since. The new project is why, and ive decided to start a project thread now ive got some way into it.
From the title, you obviously know its a MK1... I wanted something a bit more 'hands on', so a MK1 project is what I decided on. Well, a MK1 Hybrid.
There seems to be quite a few MK1 projects going on here at the moment, ive tried to do my 'own thing' by trying to get some one off things in there, but I really dont care if its the same as someone elses anymore, its my car!
Firstly, Ive mainly based this project around a blog...Il keep updating on here, but more stuff will be updated on the blog as im going along. It can be accessed at:
Now...the project itself!
Day 1
The plan is to build a MK1 Hybrid track car, mainly for use on track days, but still be road legal for day-to-day use.
After looking around for a month or so, I came across an Xeros Gray Valver, that someone over on Clio16Valver had been to see, and wrote a small review of. It seemed to stand out from the others i’d seen, so I decided to go and look at it. The car was based in Leicster, 100 miles+ from me, but I was hoping it would be worth it.
After having a good look around, and test driving it, I made the seller an offer…Managed to get it over £200 cheaper than the asking price! Bargin.
Took it easy on the way home, seemed to be running well. Ended up taking it out for a drive later on that day, which ended in disaster. After turning a sharp corner, I began getting huge screeches from a belt/pully under the bonnet, had no idea what it was. Managed to get it home, and leave it on the driveway until I had time to look at it…
Day 2
Set about trying to figure out what the screeching was today… Started the car, and turned the steering slightly whilst looking under the bonnet. The power steering pump pulley was jamming, and the belt was slipping over it, causing the noise. Checked the belt, to find it was very slack, so I initially thought the tensioner had moved.
Stripped the front down so I could get the belt off, then realised it was the power steering pumps pulley that was catching on the mount that it usually bolts into. This led me to think that one of the pumps mounts had sheared off, causing the pump to move, but this wasn’t to be the case.
Got the pulley off the pump, to find there was not a single bolt holding the pump onto the mount. Quite shocking really, as there are usually three 10mm bolts holding the pump in! Also, by looking at where the holes for the bolts are, there is no way the bolts could have just fallen out, as there is no space between the pulley and the pump. They must have never been put back in! You can see where the pulley had ground away part of the mount that it is meant to be bolted into.
Managed to get three bolts that I needed from a spare power steering pump that Winston had, so used them to bolt the pump back into place. Then reattached the pulley, and put the belt back on. Started the car and it was running fine, no noises when turning the wheels…result!
Day 3
First proper look around the car today, turns out there is near enough no rust at all. Had a look through the paperwork, its had loads of new stuff over the past year or so, full service history too. Not that it matters anyway, as the engine is being changed.
There are two main problems with the car, a crack to the drivers wing, and a key mark down the drivers door. I went round a handful of bodyshops, and got some quotes, but decided to leave it for now until the bulk of the work has been done.
The interior is full leather, in near enough mint condition, especially for a car just turning over 142k miles!
Although there a few little niggles, like the speedo is very wobbly up to around 30mph, possibly a worn cable from the gearbox, or something else. Also couple of the dash lights are intermittent, probably need a few replacement bulbs. The list of things to sort is ever growing!
The drivers and passenger doors had some silly stickers round the keyholes, passenger side came off fine, but when I peeled the drivers side off, some paint came off with it, and revealed some damage to the keyhole.
It seems its either been broken into before, or the lock has been tampered with and the repair has been bodged. Also, the cracked drivers wing looks un-repairable, the crack is not just on the visable side, the mount on the back of it is fully cracked also. The key mark to the drivers door is very deep, and will most likely need a full respray, repairing the damaged lock at the same time, I may even have the lock taken out completely.
PLEASE NOTE - If you want to view my project without the discussion/spam in between the updates, my blog is always kept up to date @ http://www.f0xy.net/
Day 1
Clio16Valver said:Good: Little to no rust at all on the boot
Little to no rust on the bottom of the doors
Very little to no rust on BOTH arches, very, very slight bubbling on the underside of the arch, nothing showing on the outside yet.
Bonnet in excellent condition
Standard exhaust in excellent condition
Parcel shelf in excellent condition
Mint condition full leather interior
Completely Standard
Standard Ph2 wheels in great condition
Loads of tread on tyres
Brand new clutch, cambelt and water pump with receipts to prove
Sunroof works and does not leak (it was raining when i went to see it)
Private plate included in sale
Drove very well indeed
Bad: Slight chipping of paint on passenger side front wing
Crack on drivers side front wing
Very tiny scuff on passengers side front bumper edge
Heard a slight knock from the rear when going over a speed bump
Drivers door has been keyed so will require a respray
Play in steering, requires column welding
The usual wobbly gearstick syndrome, needs a new mount
Day 2
Day 3
