Re: Mk1 F4R/172'd Track Car Project
Right then - Update time.
Before FCS I set about tidying up some bits on the car. The main one was finding some sheets of grip-tape big enough to cover the floor in the shape of a floor mat inside. I didnt want to use a normal mat as it would just slide about, so wanted something adhesive.
It took ages to find anything that was big enough and good enough quality - I could have used skateboard stuff but it would mean having a join in it etc and I didnt want that. I managed to find a company local-ish to me who were happy to help, and had some decent sized sheets in black that would be perfect. £6/sheet and I was pleased with how thick/good quality they were.
I set about cutting them to the shape of the standard floor mat, then with a bit of help stuck them down. Not got any pictures but you get the idea, miles better and finishes off the inside nicely. Il post some pics of the finished article sometime soon.
After tidying up a few more loose ends from front bumper mounts, to bleeding the brakes and making a center section exhaust hanger I was about ready for FCS/Rockingham Trackday. We were only going to FCS to make a weekend out of having a full day at Rockingham on the Monday, turned out to be OK in the end.
Made it down to FCS and the car was on the WilliamsClio stand, some of you may have seen it on there. Met a few new faces also who asked some questions about the car etc which was cool.
After FCS we headed back to the hotel for the night. I decided to swap my wheels over to the Superleggeras/R888's so I didnt have to mess around in the morning for the trackday. When we got up it was raining and damp, drove it to the circuit and unloaded everything from the car.
The R888's were not too bad in the damp/wet, although the track was slippery as f*ck with all the rubber on the track and added rain. The car went and drove well, and luckily the rain had stopped by 10am which meant the track started to dry out nicely.
After about 20 laps when the track was starting to dry out, I came upto the Tarzan hairpin and under braking/mid corner I got a huge vibration/knocking noise - I thought the driveshaft had snapped so held the wheel straight and went onto the grass. To my suprise when I got out the N/S front wheel had completely come off, and was jammed up into the arch. The brake disc was resting on the bottom of the rim and all four bolts were missing.
When the recovery came out, we wandered onto the hairpin and found the four bolts on the tarmac coming upto the approach of the Tarzan hairpin. I could not believe what had happened, as I religiously torque up all the wheel bolts when fitting wheels - as many of the other people there had watched me do when fitting the Superleggeras!
Really do have no idea how it managed to happen, weather the threads were weak or the bolts were f*cked who knows - I just hope it never happens again.
We tried to re-fit the wheel to get the car back to the garage but the bolts would not thread into the hub, all the threads were stripped and bolts f*cked. After managing to get it back into the pit garage, I stripped down the brakes to reveal the bare hub on the N/S - as expected all the threads were completely stripped.
After checking the other three wheels, all were still tight which made this even more odd! A few pictures of the damage to the wheel...
I need to get the wheel checked really, as im unsure if its safe to use again. One of the tapered seats for the bolts looks a bit iffy, and there is a chunk missing out of the spigot seat.
Anyway, by this point Andyrg's car had broken down on track with terminal damage, so he offered to lend me his hub (as hes running the same 172 widetrack setup as me) for the rest of the day/to get me home as his was going home on the back of his recovery truck. Swapped them round over lunch...
And had the car back ready to go on track by the time the track re-opened. I ran the Williams wheels on the front with the T1-Rs on for the rest of the day, and now that the track was fully dry it really was a good afternoon.
The circuit was a lot better than I expected, especially the very fast chicane on the first corner. With the R888's on the back it felt like the car had a lot more grip and it could really be thrown in more so than last year. Who knows if thats the tyres or the modifications to the shocks/cage, but its completely different to drive for sure.
I had issues with the N/S driveshaft throughout the afternoon giving a huge vibration round right handers, but I just put up with that and carried on. It needs replacing but I need a new hub first so I can do them both at the same time.
Had a few good sessions out on track, one with NathanH chasing me down (well trying :rasp
 and a couple with a DC2 - just lucky that Andy had a hub he could lend me or the day would have been wasted!
So there we have it, another trackday with plenty of problems - not just for me either unfortunately :dapprove: But once I got going again it was good fun.
Cheers to Andy for lending me the hub, Adam/Rob for the pics etc. Just need to sort a driveshaft, hub and possibly spare wheel now before Cadwell on the 7th July - so Il update some more soon :approve:
