im guessin ud need the whole manual adjustment workings plus the bit that fits into the dash under the steering wheel... prob wont be too expensive from a breakers
MOT? Can't remember them ever checking the height adjustment - mainly because it doesn't really do much (it's useless on the Mk1, Phase1/2's anyway)! They just check the beam alignment and change it on the actual headlight.
Either way, it ain't gunna happen without a major load of hassle.. and it's just not worth it.
There is a manual adjustment actually on the ligts themselves, just above where the conenctor plugs in, its a white knowb type thing you turn.
All it means is you won't be able to adjust the height in car if you are towing or have a large weight in the back, but i guess that isn't gonna be happening much?
