Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
im guessin ud need the whole manual adjustment workings plus the bit that fits into the dash under the steering wheel... prob wont be too expensive from a breakers
MOT? Can't remember them ever checking the height adjustment - mainly because it doesn't really do much (it's useless on the Mk1, Phase1/2's anyway)! They just check the beam alignment and change it on the actual headlight.
Either way, it ain't gunna happen without a major load of hassle.. and it's just not worth it.
There is a manual adjustment actually on the ligts themselves, just above where the conenctor plugs in, its a white knowb type thing you turn.
All it means is you won't be able to adjust the height in car if you are towing or have a large weight in the back, but i guess that isn't gonna be happening much?
