Mk2 Ph1 HIGH IDLE HELP PLEASEE :(
  3 Series touring
My cousin has a 1998 mk2 ph1 and its got a problem :s
start it up and it idles at about 2300/3000 RPM , does anyone know what the problem might be, i thought the throttle body might be gammy and stuck open , but the throttle calbe appears to pull it fully open and then back to its rest position (just by looking at the engine)
HELP IS REALLY APPRECIATED :)
Ben
  3 Series touring
the cable appears to take the throttle to full throttle andn all the way back (the metal bit turns through a full 90 degrees )
didnt take off the inlet pipe to see the throttle body, might it be dirty/sticking?
  White Clio 1.2 @ 172
Leekage on a breather pipe?
Carbon Filter pipe has come off and is sucking in air?
both of those brought the idle up on my 1.2 8v also I had a high idle once when the car was running out of fuel.
