My coolant level on my 182 is at MIN.
Da
  Less
No it should already have anti freeze in so just top up the water and away you go.
  106 GTi
Renault and GSF both also sell the coolant in pre mix top up bottles if you fancy going down that route.
  Vw caddy tdi
I'd top her up with a glyco based antifreeze (renualt recomendation) it'll just help by lowering the waters boiling point tiny amount hence the term winter/summer coolant. Keeps the waterways un corroded also the header tank dosent get mankey.If your waters still bit orangey drop the bottom hose of the rad drain flush reconect hose clip, fill with water/antifreeze mix..
