Update on the latst week
Started off by taking the subframe apart so we could get the wishbones out ready for the 172 ones, replace the valver anti roll bar with a willams one and then all new bolts and new poly bushes for when it finished
All apart, valver parts now forsale
Wot does the williams one look like ive been told its white and triple skinned
Gave it a good clean with the hosepipe and wire brush
Took the 172 wishbones to the factory to burn the old bushes out and then to cut the old metal sleeves out ready for the new poly bushes and metal sleeve to go in
Both burned out and one with the metal sleeves cut out and all the mess from the both of them
Cut out one
One that still need to be cut out
Once all the metal sleeves were out we set about putting the new ones in
Lots of copper grease is the key to hammering them in
Once all 4 were in f0xy then ground round the sides ready for welding/tacking in place
How old is this machine its even got its own foot pedal to work it sounds funny too
All ground down and ready
Welding in progress
All tacked and looking good ready for some nice couloured bushes to go in
Picked up new bag of bolts and washers to replace the old ones in the subframe
Gave the subframe a good wash down with some Gunk to get the rest of the muck off
Subframe was then wiped down and a few coats of paint added same with the 172 wishbones, no pics of them
Got the subframe home and then started to build it up with the new stuff
Williams anti roll bar with all new polybushes and bolts
172 wishbones with new polybushes and bolts
Lots of copper grease used in fitting the new bushes verry tight fit
We then dragged the subframe in and put it back on the car
I still have the challange of getting the old susspension off the car as the allen key bit on the top rounded on both sides, i ether have to find someone to lend a buzz gun from or buy one. Bad times
