Needing to change windscreen wash fluid, every 4 days...
there HAS to be a leak somewhere surely? any1 know if this is common? and where the problem usually is? leaking pipes or a leaking washer bottle?
  Carrera 4S. Clio 172. M5
Its a fair bet its the rubber grommet in the base of the bottle where the body of pump pushes in. My Sons 172 had the same problem and I replaced the grommet and that fixed it.
Having said that, its not much of a washer bottle, only holds about a Ltr.
