Re: destined for the track
Well next week was too long to wait. Pretty easy when you know what's involved, was quite hesitant at first because of the trouble Team Anorak Racing had the first time round with Fletch's bus. But after a long good look at what was involved its quite simple. Unbolt-unplug-take out, put in seat-plug in-bolt in.
Started off with jacking the car up as far as i could, there's also an axle stand under there.
So glad i have a straight through pipe here, accessing the gearbox side nuts is so much easer !
The two plugs under the seat. From what i have read and understand the left is for the pre-tensioners and seatbelts. The right is the air bag, notice as its a cup the air bag has noting connected so no need for resistors
Passenger seat out
Passenger seat Recaro in
Lunch time
Drivers side out, also found £1.20
Both Recaros in and cleaned then up Goodwood for some pictures
MOT is due Tuesday, so gotta sort out a few things tomorrow. Then hopefully the wheel will be here and fit that next weekend. Splitter will have to wait till next month tho
