New Brakes
Was thinking of picking a set of these up for my new white wheels, curious as to how they'll wear and whether they're any good though.
Will they wear in the traditional metal silver or are they like black after the first few layers of the disc are worn off?
Also will they rust as much as regular ones? Thanks in advance :)
PS was thinking of getting these brembo pads as well.
I run the brembo pads and find them very good for road use. Plus speak to G172 on here for the pads.
As for the discs i wouldn't touch them every set i have seen have cracked between the drilled holes and they also look pants.
Again speak to G172 for fronts brembo HC discs most discs will rust unless you spend mega money on some dipped/heat treated ones
