That's just your opinion. I'd pick the 500 over the 200 without a doubt.
Glad you are enjoying the car, I worked on some of the Trofeo Race cars from the series at the start of the season along with my partners dad who also has a Campovola grey 500 Abarth.
The engine is the stand out feature of these cars. Abarth quote 133bhp & 155lb ft as standard, though we have found the make about 150bhp & 160lb ft as standard with a simple remap getting you 160bhp & 180lb ft torque.
I see you're on the Abarth Forum, the information you get on there is very narrow with only paid up sponsors getting their products discussed, so only TMC piggy back box for tuning etc so look elsewhere for more comprehensive views.
The car has some fundamental flaws which means I would not drive one.
The steering on the road cars is very poor. It's not even worth driving the car out of sport mode as it's comically lite, and in sport mode it artificially firms up but is devoid of feel & feedback, it's like driving a car with the steering wheel is attached to the rack by bungee cords.
The gearchange is just ok, the standard 6speed box as found in the lesser 500 1.4 n/a is sweeter but the alfa sourced 5 speed in the Abarth has too long a throw and IMO the articulation of the gearstick is wrong.
The pedals are poorly designed with the accelerator pedal being set at the same height as the brake pedal meaning under braking it is lower making heal & towing near impossible unless you dislocate your ankle.
You sit way to high in the standard unsupportive seats, the Sabelts are brilliant but at £1500 way overpriced.
Then the biggest issue, suspension. The rear of the car does and will hit it's bump stops on bumpy A&B roads with little effort making the back end skittish, the Essesse kit makes it worse, shorter springs make car have approx 25mm of suspension travel making it unacceptable. The best thing you can do to the car is remove the rear bumpstops (they just pull off) as the car does not become coil bound or reach the end of the damper travel so no damage can be done.
We developed in conjunction with AVO & Pulce Racing a coil over mono tube suspension set up that greatly improves the car, though it is £1000+vat plus fitting if you don't do it yourself. There is a cheaper twin-tube (inferior) Gaz set up for about £850 iirc which has taken them 4 attempts to get the front spring rates right as 1st time I saw it fitted to a car it was completely coil bound, very poor, not impressed. Though on recent Abarth trackday using my partners dads car as AVO/Pulce demonstrator & comparing to Gaz set up on an admittedly not very testing Seighford track was little to choose between them.
It may sound like I'm bring very harsh to the car, but it does have good qualities. The aforementioned engine is a cracker. The Trofeo cars run standard engine with nothing more than the Garrett turbo from the Punto Essesse fitted and 3" turbo back exhaust system & with only 1.3bar of boost make 215-220bhp & 240lb ft & apart from people downshifting to 2nd rather than 4th spinning engine unto 10500 rpm and smashing the valve buckets there have been no failures. It's rumored engine on standard internals is good for 250+bhp which is brilliant from a 1.4 that will return 40+ mpg all day long.
The brakes are very strong though standard pad compound will fade if used with enthusiasim.
But as a standard package it's not as quick as my Trophy & therefore can't be as quick as the 200 or Megane you previously owned, but they are good fun & low down torque makes them feel quick & though you get no feedback the cars do produce very high levels of grip.
And the standard kit level is good, Blue & Me plus the Interscope soundsystem with built-in subwoofer etc.
The steering doesn't sound too good
How you find the steering, Lynden?
To be honest I thought the MK3 clio suffered terrible assisted steering.
As i said i do like them but lynden seems to want performance something that the 500 lacks compared to its competitors. Basically I am just asking what you gain from having a 500 over the Renault other than limited numbers.
yeh i have heard of the cars producing more than standard, mine feels like it has alot more than 135bhp if im being honest and yes the steering when not in sport mode is comical but i only turn sport off when im in traffic or im on the motorway, the steering does get alot heavier when you go over 75mph though which is nice on the motorway.
where can these coilovers be bought because i have checked the pulce racing site and they arnt on there
yes the accelerator pedal is high which means you cant heel/toe but this is something i can live with.
and yeh the steering isnt great but the amount of grip is brilliant, i went round a corner today expecting it to understeer abit and go abit wide and it didnt it just stuck to the line and then powerd out of the corner.
Weight & feel are two very different things. With electric assistance the motor is normally attached to the steering column & it's a reactive system so until you input a change it's passive, then it has to catch up giving the numb in straight ahead feel. Manufacturers try and over come this by adding resistance to the motor, but this only compounds the lack of feeling, this is where the elastic type sensation comes from as you fight resistance and then motor starts to assist.
The cars do generate grip but it doesn't signpost the levels of adhesion so you have to drive knowing it will hold on rather than feeling that it's holding on. Don't expect more than 10k out of four tyres if you rotate them, 6k on fronts if you leave them, that grip & torque does like to eat through them.
I notice in original thread you mention the Magneti Marelli Monza exhaust available through dealers. I thinks it a gimmick on a car of this level. The reason it has 4 pipes is it has a bypass valve to effectively make it bypass the rear silencer. Fair enough if you have a 500bhp exotic that needs this to pass drive by EEC noise regulations, on a hot hatch £800 for a mild steel back box, no chance. Plus those bypass valves are known to rust meaning either constantly closed or open.
We have had initial discussions with BTB exhausts who have checked the car over & are keen to do something, Pulce may become involved to, our car possibly being the test bed again.
For the AVO coil overs contact Aiden at Pulce as he fronted the money for 5 sets & say they were recommended by Jon Lloyd (my partners dad) who has the initial test set. Damping rates were done by Andy Dawson who for anyone in or has a knowledge of motorsport knows he's a top engineer, he was boss of Nissan Rally Europe along with Jon back in the Sylvia & 240RS group B days before falling out over the poorly conceived Sunny GTiR, but that's another story. Of course buying before New Year means less vat with the increase to 20% coming in.
Regardless of how good the grip is, if you don't feel connected to it then it's poor design.
Shame really, as this isn't something you can change easily.
Agree'ded'd.
Most modern hatches suffer from it though, unfortunately. Since an electric rack is half the cost of a decent hydraulic setup, you can guess which one gets the nod.
I use M Division as a yardstick. Currently, none of their products use electric racks, nor do they use runs flat tyres... for very good reason.
My problem with VAG cars (oh, not this again) is that their manufacturers think that by artificially weighting the steering, they're fooling us into thinking it's full of feel. It's not, it's dead, it's Pete Burns' face.
Renaultsport have made a good job of EPS though. The R26 being the highlight, IMO.
Also, I've heard the Bluetooth on these Fia... Abarths is really good.
I'm sure on page 7 i just read 'the underseat sub and the rest of the speakers are much better than the clio's'
If thats what you want then flol, i'm sure renaultsport couldnt give a toss about 'ice' when theyre building the awsome drivers cars that they constantly do
video of it
sounds abit deisely when its not under pressure
So one of the most important parts of a drivers car is lacking somewhat.
No too good. I'm surprised it doesn't have a "City" button.
Out of interest mate, why did you go for the 100HP over the Twingo? I tried to get her to drive the Panda, but she couldn't get over the looks. *****.
That said, I love our 133 now.
When I bought the panda there weren't very many 133's on the used car market, plus it was abit cheaper ( I paid £5k for an 07 plate) looking at about £8.5k for an early 133, plus the equipment is better on the Panda (bluetooth and climate as standard). I might have a 133 next though!
As low as that? I'd have thought (hoped) for high 30s, maybe creeping into the 40s.
i think it just jazzs up the inside of the car abit
