NO handbrake!! snapped cable or something else?
Car  CLIO PH1 172
as above my hand brake has totally given up.
When I pull up the handbrake I can see the cable being pulled(by looking at the callipers) but the 'L' shape piece that it pulls doesn't seem to move enough to engage the brake?
I have adjusted the cable as tight as possible from inside the car
I cant see the drivers side 'L' bit moving would people think that I have a snapped cable?
I still have tension on the handbrake lever itself which makes me think its not a snapped cable?
I'm confused now as to why its not working atall.
i have and they seem fine? this is whats confusing me they seem fine and like i say there IS tension in the cable when i pull the handbrake up!?
sorted - i was adjusting the cable but without pumping the brake solid first. so to fix it:
slacken cable right off (from in side the car)
pump the brakes solid
tighten the cable up (again from in side the car)
done- one solid handbrake!!
easy when you know how.
+1!!!
my handbreak pulls up to far.. so i may need to do this :P
