Oil pick up pipe
what size torx bit holds this on, there's two of them i think. Mines covered in silicone so need to remove it and clear it out or maybe replace it. No idea how it hasn't caused and further damage.
  Trophy Turbo :)
Hello matt.
The oil pump from factory is held on with 2 x 13mm bolts... on a f4
The oil pick up pipe is part of the pump so your on the right lines. :)
Hello matt.
cheers mate, mine was full of silicone on the metal mesh bit where someone used a crazy amount of silicone on the sump instead of using the oem gasket. I've cleared it out now all i need to do now is find a new sump!
