oil pump help!!!!:(:(:(:(:(
Car  m-tec bmw 325 ci spo
well ive just had my 172 engine rebuilt and it turns out my pumps fucked my oil light and service light keeps coming on had a mechanic take a look and he rekons the pumps on its way out. if you rev it to about 3k and let the revs drop the engine starts knocking. now how much is a new pump or do they do a rebuild kit and how much of an arse is it to change ?
if the oil pump is on its way out get it done now do not drive it or it wil be a engine re build aswell!sump down job
its about 2-3hours off the top of my head, a knocking engine though mate? that ain't just the oil pump that'll be fucked, did the person who rebuilt it know what they were doing?
yeh its been fully rebuilt he knows his stuff with engines but i spoke to another mechanic and he said it could be the lifters in the head if its got runnning in oil in it may be to thin for the heat? and ive just checked that the oil is also down on min and its leaking abit a out the back of the sump could this also cause a rattling top end and its only when the revs come down from about 2k to 1k it has a little rattle ?
also fred totally off topic do you know a guy called aldo ritti
why was it rebuilt out of interest? i've heard that name before
the oil rings were fucked had 40thou of play in them and the bores were ovalled
do you think the oil could be to thin for the heat causing the lifters to rattle?
he does race instruction at bruntingthorpe and its one of the best ferrari lambo mechinics in the country hes taking it on wed for a look over
is his workshop on site at bruntingthorpe?? under the diner?
so it was drinking the oil before then!
na doubt it'll be the oil, is the timing spot on???
so it'll have been bored out a wee tad and honed with over size rings, hum
yeh burning 2litres a week it was mike@rentechs old engine that had the throttle bodies on it
maybe ill get the timing check
the engine was bored out over sized pistons new shells re ground crank head was ported polished gas flowed and had the inlets matched im running out of money now so it needs sorting any ideas on what to check first?
mikey , i get £130 including vat for the oil pump , but would need engine number to confirm , im sure they are same pump in all the 172/182 engine variants. have a good used one if you want to pm me an offer.
also where abouts in surrey are you ?
haha just kidding
comp test it first
its defo the top end rattling?
yup i opend the bonnet got my old dear to give it a little rev def sounds top end but dosent soun cammy if that make sense the only way i can describe it is when you hear marbles knocking togther thats what it sounds like p.s i hope you have heard marbles hitting each other lol
hi mate thats abit more than i was hoping for how can you tell if the second hand one is in good condition im down in kingston kt6 7jt where abouts are you based matey
Renault is 82 00 741 631 and is circa £106, its had a million different part numbers in its lifetime so theres a chance its changed again.
Jesus christ Mikey, it might be time to stop rebuilding that f**king thing and maybe get the bus :p
its not the oil pump turns out the oil pumps brand new lol im gonna fix it then sell it then get a type r
