1 week mine took.how long does it usually take from order to deliver?
One of mine took 3 days the other 10 days.how long does it usually take from order to deliver?
Hi everyone,
We are pushing an update to fix the Facebook crash some of you reported since the last OTA. Facebook is actually seeing similar issues on other platforms as well since their last update, but we know how important Facebook is to many of you so we found a solution.
This update includes:
- The aforementioned patch to fix Facebook crash on open.
- Landscape mode fix. Apps such as Google Maps should now work correctly in landscape.
- New language packs for Swiftkey keyboard.
Thanks for your feedback. Enjoy!
Oxygen 2.1.1
Download the OTA Zip here :-
MIRROR 1 :- https://www.androidfilehost.com/?fid=24052804347837411
MIRROR 2 :- https://basketbuild.com/filedl/devs?...1510112055.zip
MIRROR 3 :- https://drive.google.com/file/d/0B9f...p=docslist_api
Steps for Installation :-
1.) Dirty flash/Clean flash full OxygenOS 2.1.0 from here :- https://www.androidfilehost.com/?fid=24052804347820312
2.) Flash 2.1.1 OTA Zip .
3.) Reboot System.
Forgot, sorry, but my mistake added in now.Ok, would also help if u link to the place u get the info from next time :tongueout:
Saves me searching google anyway :smiley:
Also figured it out, would help if i flashed the right file. DUH.
To much excitement then i take it?Flashed mine, then forgot I missed out:
* Xposed
* AK Kernel
* SU
Now going through optimizing apps again, and I literally have a meeting right now, oops.
Do this all time.Yep all up to date here, I didn't flash them originally as I wanted to make sure it would actually boot, it's always fun flashing 4-5 zips and then hoping, waiting.![]()
Do this all time.
Makes it all the more fun.
What are you using xposed for?
Don't need xposed for them though?Amplify, Greenify and YouTube AdAway
please mateContacted support. RMA happening. Phone is too slow when its at 20 percent.
Anyone want an invite?
What have you replaced AK kernel with?![]()
Using AK Kernel now too, it's faster, and battery life is immense. This is me using it normally too...
What kind of SOT you getting with that?![]()
@Addicted OK, so I bit....I installed AK!
What tweaks have you made to it? Any pointers on what settings I should be changing?
Screen is not even in the top 3. How surprising that pretty much leaving it on standby gives a long battery life
I left it all as it is.
Well, I was getting half of the "standby" time previously on the stock rom, so I'd say a 50% increase is good. And the Screen was at #4. This is with normal usage, so regardless of what you think, it's much better. You must be new to this thread.
Ah, fair point then. Not kept up with the thread much recently!
I really need to learn more about android and make the most of the phone. Clearly a lot to gain from a bit of customisation. Seems like it's location services that are absolutely hounding my battery. Turned them off completely earlier this morning and my battery use has nearly halved
It's a pain in the arse having them turned off when certain apps need them though.
Interesting - are you rooted/bootloader unlocked? Since adding Amplify, Greenify + AK Kernel now, my increase in battery life is literally double (if not more) - highly recommend them if want more battery life - I don't have location or anything like that disabled [emoji2] The only main thing I do is Greenify Facebook I think to 720 seconds or something - makes a huge difference from what I can tell!
I should have just rooted it when I got the phone! Now I've a load of stuff I'll need to back up first lol.
One of the best things for battery saving is to remove ANY IMAP mail client, even with IDLE they all seem to rape your battery. Biggest saving I had on unrooted/stock was to remove the email app (tried loads, k9, outlook, cloudmagic etc) and battery life went up significantly.
I obviously have a gmail account, but I hardly ever used it, so I took the opportunity to set up my icloud account to forward email to gmail, set up the various things in there for tagging the icloud mail, setting return address and smtp server for replies etc.
Then switched to using Inbox, not only does it consume zero battery, Inbox is absolutely immense. I didn't have it for ages as I have an legacy google apps hosted gmail (before they started charging for them!) and inbox didn't work on those, but now it does. Searching is the best bit, instant.
So I have push email back working from iCloud on an android device and it's not consuming battery.
