PH2 172 O/S Driveshaft rubbing against sump
Car  Black PH2 172
As title says really - Only had a quick look, Cars becoming a pain on my ass! Fuked engine mount bringing engine back? Obviously the D/S Driveshaft is 2piece, Its the side before it goes into the bracket in the middle of the shaft, Boot and joint seems to be rubbing against sump, Grease everywere!
Check the bearing carrier mount is properly bolted to the back of the block and that it has all bolts still in place.
Mick
Thanks guys - Cheers Mick, Ill give it ago - Its got a Renault sticker on it Mr.pink so I assume its genuine. We'll see tonight when I look!
