Please help me finish my build!
  Clio 172
Hi all,
Almost finished putting the engine back together on my 172 after a bit of a rebuild, and missing a certain item;
Desperately need an air com pump bracket if anyone has one spare please?
I've rung round loads of breakers and no one seems to have any or will part with one, without the rest of the engine.
Help?!
  Clio 172
I should clarify that I have actually remove the aircon pump, but presume i still need the aircon pump bracket to hold/locate into position the alternator… is that right? I have the bits to make an aircon delete as suggested in another thread on here
  Clio 172
Thanks for that. It is in fact just a home made kit i found using a Toyota Avensis pulley (larger than existing, to accommodate for the lack of aircon pump pulley) with alternator in same location. Has anyone on here tried this and know if i need the aircon pump bracket? I'm pretty sure the thread was on this site?!
  Clio 172
an image from the manual i've found
