Right cooking on gas now:
1) cleaned and fitted stops, rocker arms and cams.
2) new seals for cams, timing end, didn't lube them so hope that is correct.
3) applied RheinoPlast to main cam cover. Wasn't sure where is was supposed to go, so went ape sh*t and put it everywhere.
4) fitted cam cover and torqued as service manual
5) cleaned up excess sealer from what I considered Critical faces.
QUESTION: on the non-timing end of the cams, there are notches in the cam. As James pointed out they are slightly offset from centre. The service manual says to rotate cams so that they are "offset downwards as indicated by diagram". I have attached the diagram at the bottom of this post. The diagram is as clear as mud and does not indicate anything. My interpretation is that the cam notches should physically be sitting below the centre line of the cam, and the cams should be in that orientation - BUT as I have already spotted several mistakes in this service manual and can not clearly see the diagram I want to check with you guys? Obviously if I get this bit wrong then I am going to smash the valves again. Can anyone please confirm that the notches should be lying south of cam centre-line at this stage of the build? That is how I read the serive manual.
