Just bought a stripped out Clio 172 '02 from my mate and having trouble starting it. It starts ok using a booster pack, which is how we got it on and off the transporter, but it wont start on its own. I don't know too much about the electronics side of things so bear with me please.
I charged the battery and tested it with a multimeter, and it read around 12.7v, then when I disconnected the charger it dropped down to around 12.1v. Does this mean the battery is pretty much dead or maybe something draining the battery? The battery light also went off when I started the car with the booster pack. When I turn the key to ignition to try and start the car, the battery drops to around 7-8 volts every time it tries to start.
As well as this, these is a strange issue when trying to start the car without the booster pack. In the video below, I first turn the key to position 2 (where all lights come on the dash then go off) then turn the key to ignition, and the engine just clicks. After that I went from key in position 0 straight to turning on the ignition, and you can see that if I turn the key from position 0 straight to ignition, the whole dashboard goes crazy and the main beam headlights flick on and off occasionally.
Any help or advice would be greatly appreciated. Thanks.
