power steering + abs
CLIO-Si
Car  1.6Si + 182
having troubles with my new clio2 00 si 16v
the abs i found kicked in to much to start with when i was just slowing down normally it used to kick in too much i thot,now my abs comes and goes sometime i have it and the light aint on an then the light appears and i have no abs,when it is working it isnt as strong a kicking as it has been before.
The power steering is kinda similar heavy one minute light the other i noticed i was below min and refilled on sat,its not going down to quickly well in 4 days its went from max to about the middle.
Im just wondering if any1 has had similar problems with there power steering system and ABS problems,
any input would be gratefull recieved thanks.
also got a leaky manifold well the front of the exhaust system which is s**t cant really do anythin bout it
ABS problem - At a guess this could be down to a dodgy ABS sensor either faulty or lose on the connections, which lines up with the fact the light coming on and off. To check, whip each wheel off and you will see a black cable fixed to a point behind the brake disc, check it is not split.
Power steering - Sounds like you may have a leak somewhere as it shouldn't go down in 4 days that much.
