Problem changing brake fluid
I'm currently changing my brake fluid using a Sealey pressure bleeder.
I've pressurised the system to 15psi and I've cracked open the r/n/s nipple but there is barely any fluid coming out. Been here nearly an hour and only collected less than 100ml.
What's going on???
Its possible I suppose.
I moved onto the front which worked a dream on the N/S but the nipple is rounded off on the O/S/F so I will have a think and finish the job another day.
Heat it with a blowtorch, then rapidly cool it with WD40 or plusgas, breaks the corrosion and draws the penetrating fluid into the thread.
Also, its a good idea to change the brake nipples to stainless versions if you have the mild steel versions.
Source: I snapped two nipples when trying to bleed them.
I have some stainless ones en route at the mo so will fit those once they arrive and give it another go. Im hoping its just the nipple thats blocked.
