I have just recently had my clio 2.0 16v lowered by 30mm
using inside splines? explain?Quote: Originally posted by DAVE77 on 22 September 2003
Mines dropped 60mm at the front and 70mm at the rear, and mine doesnt catch.
The 55mm drop at the rear on 1 spline is if you use the outside splines, I found that if you use the inside splines you can adjust the rear suspension to whatever hight you want.
Dave
Quote: Originally posted by DAVE77 on 23 September 2003
The spline on the inside ( where it slides into the bit in the middle of the axle), are a lot smaller than the splines on the outside, so you can adjust the rear suspension a bit more acuratley.
When I first lowered my car, I used the outside splines, but this lowered the car too much. So when I took it apart again (to put it back to standard, so I could take it to be lowered properly) I found that the splines on the inside where a lot smaller, so with a bit of trial and error, I got the rear level with the front, which had been lowered with springs about 6 months earlier.
and u did it yaself? how easy is it to do?
