Will send me a link of the fabric ur using as mines black and want a closer oem colour for the roof
Colour im using atm![]()
looks good man!
the plastic you can remove. wiper puller or ball joint splitter on the wiper arms and pull them off, then it clips off. I took mine and satin blacked it out, as it was going grey!
also the whistlers look insane! :hearteyes:
Its not that bad to work with tbh.Love this, attention to detail is insane
Half tempted to give my interior a freshen up with the suede/alcantara material but I don't think I'd have to patience
What size fabric did you use for the roof lining? I sizeing up my next order.Didnt get to go FCS in the end as the service/work took longer than anticiparted. Bit annoying like.
Anyway... Service done+alignment.
Few more bits done by the bodyshop. Colour coded washer jets + aerial + base. Arch lips rolled and filled. No more rubbing on the back now.
Few more small bits to pick up next week or so, from the bodyshop, for the interior.
Seeing as got a bit time now this weekend finally started fitting bits back in, de-bobbled the seats and a vacuum.
Bought some other material for the headliner, with a bit of colour! Love it. Bit thicker than the black stuff I've used which made it a fair bit easier but even then... still a b**ch. + done the side parts of the seats.
Given the parcel shelf one final coat of the fabric spray and stuck the 2 sprayed bung bits back on it. Couple of marks on them are just water smears.
Couple more bits for tomorrow to fit such as the foot rest, mat clip, sports mats going back in, back interior panels and the below/visors. These bung style clips were an actual c*nt to get off and so far..and actual c*nt to go back in. Should be fun :rage:
Just read this thread from the start to finish............... all I can say is, WOW!penmouth:
The difference between those first photos on page one and now is like night and day, the car is a credit to you chap :up:
After all the work you've put in making it a one off, i'd find it VERY difficult to sell it now lol!
Maybe a few small bitsYou doing any more purple?
Headliner was 1mm thick. MUCH easier than the cheaper thin black material I've got.What size fabric did you use for the roof lining? I sizeing up my next order.
Gonna look into doing some of this suede stuff myself, so will have a look around on eBay I assume is the best place to get it?
Also, do you think it would be possible to do the Dash in it? Would make a change from a flocked one
More great little touches, when you start colour coding stuff you suddenly realise how much there is!!!
Mine had been doing the same this last week. Doesn't like starting first time. I'm going to go the scenic route home this morning to give it a blow out. I'll probably be reporting it as dead tomorrow [emoji38]Just ticked over 70k miles so time for cambelt/water pump.
Not starting very well lately, well... didnt even start tonight after work for a while. Had to roll it forward and pump the accel and finally spluttered into action with the added enjoyment of the engine light on. So errr not sure about that one. Ill get them to have a look when its in. Lets just hope it's a nice and cheap fix like spark plugs 😅
Tax is also due end of this month. Expensive few weeks!
