If your putting an OEM stud into a catcam then you dont want to be bottoming it out to torque it. If you do then the install height will be 5mm shorter than it should.
Install it to the same height as a stock cam (you can just put the cams nose to nose and measure till they butt up). Use PROPER extreem thread lock. Once you torque up with the nut the stud will pull on the threads in the cam anyway and it'll be fine.
