Question about exhaust (making one)
  Iceberg 172
Hi all, I've been after an exhaust for a while and havnt really found anything, I've done a bit of research and am thinking of making an exhaust. Firstly to buy just a centre section off eBay, cut the flanges off and weld them onto a bit of stainless steel tubing from B&Q for £10. Weld a mounting bracket and use as a hanger. Am also thinking of buying a de-cat pipe off a friend as well. So the finished product should be like a peashooter exhaust :). I'm just wondering if anyone has tried this before or if anyone thinks it's a good or bad idea.
Cheers for reading. Opinions will be helpful.
Sam
Sam
North East
  Electric 🔋
£10 for stainless steel tube from B&Q ?
What do you get, 100 MM ?
You can get stealth systems on here for pretty cheap or you could get one made up at any exhaust place.
I guess it couldnt harm to try it though.
  Liquid Yellow 182 FF
pretty sure this will sound s**t. Heard a 106 gti that did the same thing and it was shocking tbh.
Daniel
  Whichever has fuel
My mate built his own using various parts from a magnex system, plus a silencer from Merlin motorsport. Sounded amazing.
I don't really see a problem with it if your a competent fabricator, out of interest do you work in a engineering place and have you tried TIG welding? It can be tricky to master.
Personally i would not use a £10 piece of tubing from B&Q the quailty will be rubbish, you want a decent high grade stainless IMO.
  Turbo 182 Alfa 159
Plenty of pipework available on ebay. Know a few people who have done it for various cars and they have turned out great.
Sam
North East
  Electric 🔋
Just to add, its going to be loud. Ridiculously loud.
Your going to attract police attention and I'm sure you can get done for not having baffles / cat in your car.
That is all.
  CBR1000RR Fireblade
I made my own centre pipe for my VTS.
I used a magnex back box, some 316 grade stainless 54mm NB tube, the flange joint off the magnex and the bend that went over the rear beam at the back was a random make.
That sounded really good with the cams and a cat replacement pipe.
