Raceland Coilovers Knocking from front
  Clio 182
Any ideas guys?
Were a right pain to get these to fit!
There scrubbing on full lock etc..so will make them a tad higher, plus knocking happening when setting off or on full lock, or going up like a raised driveway?
  Ph 1 172
Sounds like top mounts might of gone I changed mine when I put my raceland coilovers on, and what did you have trouble fitting them with? Are you sure they are fitted correctly mine where on within an hour
Probably less
  Clio 182
The rears were easy, the fronts no matter what, wouldnt align up with the hub hole things, so was a right pain.
Off the raceland i kept the metal bit that sits on the spring, and used the big rubber thing off my old top mount, put it on, and through and put the top mount on and tightened it back up
