The fact that these have in fact come from ECP has completely shat upon my illusion that these were straight from Marelli
The one that is incorrect btw..............was actually opened and has been sealed shut with an ECP (IWP042) sticker......I can tell because of the dirt under the ECP sticker........the Marelli sticker underneath says IPM012. It was opened at some stage.
My apologies, I too was under the illusion that Renparts only sourced the injectors from Marelli, which was the case with the one`s myself & other`s have
received.
IPM012 is indeed a Citroen/Peugeot/PSA injector.
Any future recommendation I make regarding Renparts injectors will have a caveate recommending that the buyer checks first that they will supplied with items
marked only with 805001446001.
Hopefully Renparts will learn their lesson, and declare they are out of stock, if there is a supply problem, rather than tarnish their reputation by sourcing from
ECP.
Some people probably just thought I was having a rant when I was critical of ECP`s returns policy, but your experience is the proof of what I said, thank you.
My apologies to
@Landyman if you don`t receive the correct items.
