Rear Brembo HC discs and DS2500 serial.
I'm planning a discs/pads change, because mine are nearly gone, and i'm
oriented to the HC group N Brembo discs and Ferodo DS2500 pads.
I found the serial of the front discs, but because the catalogue on the site is
under update, i can't find the serial for the rear discs. Any idea?
And about the ds2500 front pad, i have two serial number with two type of
pads slighty different. The FCP406H and FCP565H. Do they fit the same way
or i have to unmount one of my front pads to see the right one myself? :)
Thanks!
buy the rear disks from fred , they sell them with the bearing and ring on and they are renault ones. dont bother with anything fancy for the back, the back does feck all braking
Hadden said:
Thanks Fred,
any suggestion to an alternative brand/solution for the rear discs? Or should i buy
the original ones, since i have to change also the ball bearing? :)
The rears do sweet FA, Std is fine.
