Rear exhaust mounting 1999 1.2
Car  Clio 1.2 1999
Just had to change this - what a b****er of a job!
Two of the bolts sheared off and on the other one, the captive nut broke loose.Managed to cut off the loose one with my Dremel, then I drilled the mounting point( which is probably only about 2mm thick) and fixed the exhaust bracket with 3 self tapping hex-head set screws. Fingers crossed !
