relocate battery, more space for airbox!
Car  RenaultSport clio 172 mk2
Has anyone considered relocating the battery to the boot?? It's not as hard as it seems, quite easy actually. This would create a lot more space in the engine bay to place a less restrictive, cooler induction system. I'm surprised no one has tried (that i've heard of anyway!). If anyone has, how did it go? A heat shield could quite easily be placed across the engine bay, protecting the newly located airbox from the radiator/engine/exhaust heat.
Any thoughts anybody?? I think it would be the most efficient means of getting cold/dense air to the engine.
Any opinions would be greatly appreciated,
KR~
y0z2a's Cup and the GDI demo car both have the battery relocated.
We've already done it
its very easy, i've done it on the GDI car and the Yozzasport car
all you need is a battery box, a 5m length of 4wg power cable, a distribution block (fused, no need for this, but its wise to be safe)
i also put in a cut off switch (safety again)
someone will have pictures no doubt
Wow, yozza's car looks pretty serious!! What is the GDI car? Any more pics of either?? Thanks
Insulating the exhaust manifold with some exhaust wrap and putting a heat shield over it should go a long long way towards keeping engine bay temps down.
Getting something like a K&N typhoon or prospeed custom jobby will move the induction cone far away from the engine and its heat.
Or a sealed air box and more heat shielding and big cold air feeds will also work well.
Im thinking of moving my battery to the boot and adding a second one for my ice ;)
It helps alot with wrap on the manifold... take a while to do and you do need the manifold out.
Fred fitted the battery box in my clio, we have since done another one for a customer so he can have more ecus in his bay!!!
yup, its an "angry car".... roars... 225 bhp and very quick.. not much on a track cliowise that can keep with it.
A.
Let me know if you need an Optima battery as we sell them.... got a mate that runs a battery company and he gets good prices on them
how would you put more heat shielding on a standard airbox? what material would you use? Couldnt you relocate the airbox as well and customise it?
