Removing air-can....worth it?
Chris205
  Many Things
Being weighing this one up for a while now. I never use my air con and from what I hear its just dead weight being carried around.
To the people who have removed it has it made much of a difference in performance and power output?
  TrackCar & F30 330d
It doesn't give you any more bhp but I think the torque increases. Because the engine has less mass to rotate then if you remove the ac the it's like having a lightened flywheel, so the engine will go up the rev range quicker.
Chris205
  Many Things
Ah ok, I was speaking with someone who said the less auxillaries on the engine the more power they tend to make....probably meant power steering etc as well
  Stripped yozza'd cup
It does free up a few hp, the same as removing the power steering. Any auxiliaries on the engine will sap power.
But regardless, the aircon weighs a lot so it's worth doing either way.
  182
mine is going soon only because I feel its in the way of my bodies but £400 fitted for saving 16kg oofftt!
