removing PH1 rear bumper
  Glacier White PH1
combed through the cs guides and have used the search tool but failed to find a clear solution, so sorry if im asking this question for the 100th time :dapprove:
basically, wanting to remove the bumper so i can CC the black strip ont' back and was wondering if anyone knew exactly where and how many screws are holding the bumper in place (apart from the four huge ones visible when opening the boot lid).
will have a proper look tomorrow anyway, but if someone already knows i'd be grateful cheers :)
  Dodgy one
Top 4, Couple under the arches and a few (4 ithink) under the backbumper, Theyre all visible with a torch, and they're all bolts
Rob
As the man above says really...
The four along the bootlid are torx25 bits I believe, then you've got 13mm (iirc) bolts in the arch liners, and two more directly under the car, think that's your lot.
The guide is the same as the ph2 bumper mate if that's easier to find.
  Glacier White PH1
cheers lads, were exactly where you said they were and finally got it removed after 2 hours of pain, the only problem were the insanely rusted and therefore impossible to remove screws :)
