removing rear wiper...
Trying to remove my rear wiper so i can move it up a notch but its stuck solid, can get the bolt off but cant budge the wiper :( Any tips ? Ones ive done before have just pulled off...
Cheers Rob.
Wd-40 and when you pull it, push the joint down into the window making it run down the splines
I tried this a few weeks ago. Stuck solid. Gave up in the end.
The easiest way is apparently to get someone with the specialist tool to pull it off.
+1
ive got a new wiper motor waiting to go on, but its stuck solid! My grandad reckons he has a pulling tool, as already mentioned, so im tryin that 2moro. Sawing the spindle has even crossed my mind.................
plaster it in wd40 and then leave it to soak in an give it a few taps with the hammer whilst moving it back and forth. Thats how i got mine off when it was solid
ahh thought they cost more than that..
When people say tap with a hammer, i thought i was pulling it away from the bootlid, so how would you get a hammer behind it ? lol
molegrips.... wedge one side behind.. and the other grippy bit on the pole that sticks through the wiper...
pull.....
jobs a good'un
With this tool I dit it...
http://upload.wikimedia.org/wikipedia/commons/thumb/6/60/Poelietrekker.jpg/358px-Poelietrekker.jpg
Interesting, i might have to invest in one of those.
Once the wiper is off, can that plate be taken off? As mine has faded in color and looking grey, want to paint it again to make it fresh.
yep..
self explanitory really the hook on the bottom hooks under the wiper arm screw acts against the threaded part on the actual motor do it up pulls the wiper arm off
Ahhh ok.. i'll give it a go..
If i'm having no luck, i'll come find some help off ya Ditz!
lol, i got the hump with mine and cut it off with a die grinder.
never had a problem getting wiper arms off of any car before bit of wd and a good hard yank/pull and i normally get them off but my rear one wasnt moving for nothing
I just want to take off the base plate and paint it again, coz its gone grey and yucky! lol
Just to warn you, it may be VERY tight!!! When i used a puller on mine, the bang was so loud i thought it had broke the glass for a split second!! b**ch ass tight!
Give it a few knocks on either side not behind it, it usually loosens at an gets it off the ring thats its seized on.
And that looks like a mint piece of kit!
